E85 help
Old 10-16-2014, 01:06 PM
427-6spd's Avatar
Default E85 help
Im pretty new to tuning and you sure seem to be the guys that are friendly and helpful to ask. I did a ls3 swap into my 69 camaro it has headers and a g6x3 cam with stock injectors. I recently just added all the hard parts ethanol sensor and 60 pound injectors to the car for the e85.Can you help me with turning on the correct parameters for the fuel if i attach my tune. I also havent quite figured how to rescale from my stock ls3 injectors to the 60 pound too. I was even slightly confused at what pids to log to watch the ethanol percentage also. I would really appreciate your help I dont want to mess anything up and im a bit nervous thank you to all those that reply Im trying to learn the best I can. The injector flow rates are suposed to be 682.5cc/min
Old 10-20-2014, 02:11 AM
1320's Avatar
I added 28% to the ve table to start...and ironically , amazingly close. I took out about 4% on the dyno with the wideband in a few spots.
Old 10-23-2014, 05:52 PM
427-6spd's Avatar
Perfect thats where i think I will start too. Who is using efi live and what pids do you suggest I log when i fire it off?
Old 10-24-2014, 10:51 PM
JtCanyon's Avatar
If your not forced induction there is no benefit to running e85 unless your like 14:1 compression
Old 10-25-2014, 08:14 AM
maroonls1z's Avatar
There is benefits to running e85 beyond power. And even in a N/A car you still pick up SOME power did to more timing
Old 10-25-2014, 08:33 AM
CAMSTER's Avatar
Default Yei sayer...
E85 burns clean smells good makes more power and if that wasn't enough how about length and a half even on low compression stock engines.
Engines run much cooler cheaper than gas my favorite race street pump fuel.
Used for excess of 30psi boost.
Old 10-25-2014, 04:26 PM
427-6spd's Avatar
Well as of now I did pick up 16 whp and 22 ftlbs by just activating the e85 in the car and IAT also dropped, so all the naysayers I say try it your self I even kept the stock ls3 injectors. But you are right Im prepping for a whipple 2.9 for even better results.
Old 10-25-2014, 04:34 PM
yelo04goat's Avatar
e85= poor mans race gas.. good stuff if you get a consistent blend
Old 10-25-2014, 09:53 PM
JtCanyon's Avatar
i run e85 only in my turbo truck on 20psi i know the benefits, but 16whp in a na car compared to the loss of gas mileage isn't worth it, imo. IAT shouldn't be affected with e85 unless your spraying it at your air filter, it has no effect on the air coming into your intake pipe. you will see a difference with egt though. now when you whipple it e85 all the way
Old 10-26-2014, 02:16 AM
Moderator
91parkave's Avatar
First off there's no rescaling your injectors you input the new injector tables from their manufacturer. You enable flex fuel under the fuel tab. Look under your stoich Afr table and ensure its sloped in regards to ethanol percentage. Fire it up and scan and drive.
Changing airflow tables is wrong when you're changing fuel. Its completely archaic.
Old 10-28-2014, 10:36 AM
joecar's Avatar
If the VE and/or MAF tables are already correct, then leave them alone (as was already mentioned, why would you hack the airmass/airflow model when you are simply changing fuel...?).
You will set B3601 (stoich AFR of fuel being run) to 9.7 (which is the stoich AFR of E85).
You would look carefully at the PE table and make sure that it is something like EQR 1.175.
You would make sure that PE enable tables/parameters allow PE to enable sensibly (see 2002 Camaro tune for a good example).
You would set B4001 (IFR table) from the new injector specs, scaled from rated pressure (43.5 psi) to your measured rail pressure (58 psi)... to rescale, multiply the rated flowrate by the squareroot of the pressure ratio.
You would also set the various other injector tables/parameters from the injector specs, as provided.
You might also add some ignition timing since E85 has a higher effective octane rating.
If you goto the EFILive forum, log the same pids that the Calc.VET thread suggests.
Old 10-28-2014, 10:38 AM
joecar's Avatar
Also, having a manifold-referenced FPR will mean your IFR table should be flat.
Old 10-28-2014, 10:40 AM
joecar's Avatar
Are you using an E38 or E67 ECM...?
Quick Reply: E85 help
