T56 to 4l80e Swap
Old 03-11-2015, 11:11 AM
455GTO's Avatar
Default T56 to 4l80e Swap
I have a 2002 TransAm and recently swapped to a 4l80e using the Speartech harness. My tuner is unsure of how to get the car to shift on its own. He switched the trans option from manual to 4l80e but it doesnt seem to work for tuning. He thinks he will need to buy a credit from hptuners and download an auto car onto my ecu. Is this the case, or can we just download an auto tune that some one can send me? Not too sure on how to make the car know its an auto now. Thanks!
Old 03-15-2015, 10:30 PM
LSX Power Tuning's Avatar
It depends on how the harness you have is wired. If it's wired to use a relay and a 4l60 tune then you'll need a 4l60e tune. If it's setup to run like a 4l80 then you'll need to do a segment swap for the 4l80.
Old 03-16-2015, 12:16 PM
455GTO's Avatar
So the tuner was able to get the trans tuned and it works... Only issue now is a constant idle surge in park and while slowly rolling in D. Once I'm at a dead stop, the surge goes away...
He tried playing with different tables and couldn't quite get rid of it... Is this an IAC issue? Again, its only when rolling or in Park...
Old 03-16-2015, 12:45 PM
Jacktuner's Avatar
Whats the cam specs?
Old 03-16-2015, 03:20 PM
455GTO's Avatar
Its the Texas Speed Torquer V2 cam.
232/234 on a 114LSA
Its weird that it only surges and dies when im rolling slowly like up to a stop light or in stop and go traffic... If im dead stopped its fine.
Old 03-16-2015, 04:29 PM
Moderator
mrvedit's Avatar
Surging is too fast for IAC correction; the idle ignition compensation should handle it.
As LSX has pointed out in other posts, many tuners run too much ignition advance in the idle advance table. This prevents the idle advance compensation from being able to smooth it out.
There are separate idle ignition tables for Park/Neutral and Drive. Sounds like the Park/Neutral table is off, perhaps with too-high values.
Old 03-16-2015, 05:46 PM
455GTO's Avatar
So for it to surge when rolling it is most likely a too high of timing issue in the idle advance table? When logging we were seeing the timing drop down to 10* and surge back up and down
Old 03-18-2015, 12:32 AM
Johnv's Avatar
Is the PCM seeing a VSS speed signal ?
Could be something in the rolling idle tables.
I agree with the above also, the timing value that gives the smoothest idle won't necessarily give the most stable idle.
lower timing and more airflow may work better.
Old 03-18-2015, 09:55 AM
455GTO's Avatar
Yes, it is seeing the speed for sure. When looking at the tune live, the timing at idle in park goes up and down from 10* to 24* like a roller coaster... Same when its slowly rolling... Should the timing in the 400-1000rpm range be around 10* maybe?
Old 03-18-2015, 10:24 AM
The timing shouldnt be going up and down like that.
Old 03-18-2015, 10:39 AM
455GTO's Avatar
Would the cause be too much timing in the low rpms?
Old 03-18-2015, 10:49 AM
No way to know without seeing log and tune. It could be too much or little, or airflow tables not being right. Thats whats most common but still just a guess without seeing any data.
Old 03-23-2015, 11:48 AM
455GTO's Avatar
Hey guys, so my trans problems are so intermittent its frustrating... Tuner is first time tuning automatic and what he did was just use the auto tables already in the tune and adjusted those...
There was no "segment swap" done nor did he download an "auto file" to load onto my car... Is this why there are issues? How do you normally change from m6 to auto in the tune? He isnt sure if the problem is just using the auto tables that are built into it... HELP
Old 03-23-2015, 12:26 PM
I always do segment swap on a 4l80 swap unless its being ran like a 60e then I start with a stock auto tune.
Old 03-23-2015, 12:36 PM
455GTO's Avatar
This is new to both my tuner and myself... How do you get the 4l80e segment and where in the tune is it downloaded? If I post my tune could you take a look at it and see if its possible? Thanks!
Old 03-23-2015, 12:45 PM
You can do a 4l80 segment on a 2002 fbody, I have done tons of them. You have to have another tune with the same OS (#12212156) and a 4l80 to compare to in order to do the segment swap. I would also start with an auto tune and then do the segment swap.
Old 03-23-2015, 01:20 PM
455GTO's Avatar
How does one obtain that tune file?
Old 03-23-2015, 01:43 PM
You can try here, there are stock files there, atleast the last time I looked there were.
https://ls1tech.com/forums/pcm-diagn...ed-2012-a.html
I dont really use that site since I have stock tunes for almost every stock vehicle just from years of tuning. Dont take this wrong but it kinda seems like who ever is tuning your car may be in over their head. I could be wrong but thats the impression I am getting reading your post.
Old 03-23-2015, 02:12 PM
2xLS1's Avatar
That's being kind.
Old 03-23-2015, 02:54 PM
455GTO's Avatar
Thanks so much for all your help! And yes, my tuner is a buddy who has only tuned 6 speed cars and just does it on the side... So its a learning process
Quick Reply: T56 to 4l80e Swap
