MAF question '04 truck
Moderator
Received 1,836 Likes
This is for my 2004 suburban - trying a shot at doing this myself from stock.
The truck is stock, except for a LS6 cam (I know, I know) and a melling oil pump. 192,000 miles on truck, 40K on the motor.
I faulted out the MAF to force SD mode and begin logging for VE, and the truck immediately ran better. So, I cleaned the MAF and put it back in MAF mode with no change, and then bought a new MAF with no change. Always pulls harder and uses less gas (according to mpg calculator on the dash) in SD.
So, other than MAF calibration, which will just have to wait until the VE is finished, is there anything else I should look for that would cause the truck to run better in SD vs MAF?
I know I could just leave it in SD, but I would like to understand the why of it and use the MAF like it is designed. Purely an educational experiment.
Moderator
FYI, MAF is screened, fully intact
Moderator
Yes. I'm going to leave the MPVI in the truck and drive it for about a week and get several logs and make sure the VE table is right. Then, yes, I'll take a shot at the MAF calibration.
I would say your maf is making it run rich. I am sure once you tune the maf you will be good.
http://www.hptuners.com/forum/showth...096#post121096 I like this for tuning the maf very simple and works great.
Datalog the truck running SD then again in MAF mode. Compare both runs and find how much gas/timing is commanding, then adjust.
You should get the same power with either SD or MAF
Moderator
Logging it some more today. My dashboard readout is already 1-mpg higher than it was, and that's on 20 miles of city driving.
Moderator
This is going to sound laughable, but on a suburban, this is a big change.
I was getting 12.7 mpg. Still logging and fine tuning SD, but I'm at 14.9-15.0 now. City driving for both numbers.
Wife even commented on how much smoother it runs.
Should have bought HPT three years ago
