will this Wide Band work with my older version of HP tuners Pro?
Conscensus is to stay away? I can get it for $100. I really just need a wideband controller to feed into hptuners. I don't ever plan on keeping an actual guage in my car.
If it's not worth $100 and the headache with the floating ground I am leaning towards the NGK NTK Wideband for around $250.
Normally though, you can fix floating grounds by tying the two together... Does that not work?
Anyhow, just looking for honest input if its worth my $$ or not.
that was basically my fix for it, run a pcm ground through the firewall and have all the gauge grounds terminate there. the lc-2 does stand alone data logging which is cool if you wanna use it on other cars, like obd1 stuff
$100 is a good deal. I prefer the aem uego now since it's dead simple to install, no calibration required.
Guy sold the 02 sensor, so not worth $100 now. I had an AEM uego in my ford lightning, but I don't remember anyway to get it to port into hptuners. I was running the gauge as a standalone. I want something that feeds into HPTuners, so I would need some sort of controller correct?
Well, I went with a used NGK AFX module. They are supposed to be made by ECM. I felt I got a good deal on it too... $135. So as long as it works as intended I should be happy.
