Cam guys quick question
Originally Posted by HumpinSS
How much timimg was removed from your tune compared to stock or was timing added?
What cam do you have?
I would think with that cam you would be adding timing. My 581/581 224/224 114 +4 is still on the stock timing. No KR. Looks like I am going to need to swap injectors as the PW is too high for my preferance
HumpinSS - what heads do you have? If they are stock you shouldn't need to reduce timing. If they are LS6, or equivalen,t you might try an LS6 Timing table to start with.
I agree with ataylors post above.
joel
joel
Stock ls1 heads. I am onna try a few more things before i start fooling around with the timing. I think i am geting lean misfires or something liek partly because the I am forcing the computer to add fuel (+ltrims) and i dont think its adequate enough
