Can anyone with HPtuners take a look at my log?
Well my HP tuners package came in the mail today and I did a few small logs...I'm really new to this tuning stuff. Is there anyone out there that wouldn't mind looking at my logs and telling me what you think...I can e-mail the log file to you? I think my bank 2 o2 is acting a little weird, and I'm having some trouble with surging at low speeds. I was able to fix the cruise control effect though using the decay feature. Anyways if anyone is interested in seeing my log or bin please let me know. I'm kind of clueless right now and need help reading and comprehending all this data that I just collected.
Matt
Matt
Excellent, do you need them exported to excel or can you read the hptuners format? I'll run home at lunch and get the laptop, all the files are on it. I'll try to e-mail them to you around 2:00 central...BTW my mods are almost identical to yours, except I'm running the G5X3 cam on a 112, and I have an A4, and 3.73's.
send me a copy too, ill take a gander at it. i always enjoy comparing logs too
.hpl or .csv is fine for me
dave@cfbinc.com
dave@cfbinc.com
Thanks guys. I'm still having some major idling issues while in open loop. I can idle fine in closed loop. I think that my IAC's are stil too high. I'm hoovering around 120 when completely warmed up with the A/C off. I would like to get them around 40 with the A/C off and around 70 with it on. I'll be fixing that in just a few minutes with a little drilling and a little T/B blade cracking. Then I will reset my trims and get some good logs tonight. What parameters should I be logging for you guys to look at? I know the obvious
RPM
STFT's
LTFT's
O2's
KR
Timing
What else would be helpful? Also can you guys look at my flash files as well or just the log? Thanks,
Matt
RPM
STFT's
LTFT's
O2's
KR
Timing
Matt
