Air Pump & WB O2 sensor
Old 07-24-2004, 10:40 AM
Bill's 02 Z-28 SS's Avatar
Default Air Pump & WB O2 sensor
Hi Folks
How do I turn off the air pump using HP Tuners?
When I used the WBO2 sensor, they claim that the air pump adds air (which I understand) and lean out the AFR. They recommend to disable the pump, I would like to do with HP Tuners software vs disconnecting the belt or what ever.
Thanks
Bill
Old 07-24-2004, 11:06 AM
HurricaneZ's Avatar
Originally Posted by Bill's 02 Z-28 SS
Hi Folks
Thanks
Bill
This only happens for the 1st 2 minutes after a cold startup, verified by my wideband commander.
Old 07-24-2004, 07:08 PM
Bink's Avatar
Hi Folks
Thanks
Bill
Pull the fuse. Sorry, I don't know which one it is on fbods.
joel
Old 07-24-2004, 07:18 PM
monodax's Avatar
Hi Folks
Thanks
Bill
You could also disable it by setting the Air Pump Disable Coolant Temp to something really low. I haven't tested this but it does seem to coorespond to when it cuts off. Mine is set to disable @ 14 degrees F from the stock program so this would make sense as it cuts off pretty quick after I first start the car.
Or you could pull the fuse and delete the code.
Old 07-25-2004, 07:43 AM
Hi Folks
Thanks - Pulling the fuse sounds like the easiest approach to the problem and my factory setting is also set to 14 degrees F - that is what confused me. I guess the question begs to be asked, why have the pump if it is only used during start up???
Bill
Old 07-25-2004, 08:37 PM
SSpeedracer's Avatar
Less emissions to ruin the environment. Catalytic convertor is not up to operating temperture yet.
Old 07-26-2004, 07:06 AM
Thanks - That makes sense but expensive.
Bill
