Need help: Predator wont fix speedo!
I just installed 4.10s in my car and I cant get the speedo correct. I adjusted the factory tire size and the actual tire size and put in 4.10 on the gear choice. The odometer is 2 tenths of a mile fast. I tried resetting the parameters and putting the computer back to stock then reflashing and nothing works. For the time being I took the Predator program out and reinstalled my Hypertech just to get the speedo correct.Maybe Im doing something wrong. Any assistance would be greatly appreciated.
Moderator
There are some combos that the Predator
doesn't work right, for, and you have to
fake it with some other wheel/gear settings
to get the right result. I guess if they were
putting out updates anything like was once
represented, it'd have been fixed by now.
Yeh.
Yeh.
Call Diablosport and tell thewm you tire size/gear ratio and they can tell you what to change the tire size in the pcm to. Changing the gear ratio in the predator does absolutley nothing as I am sure you have already figured out.
Brad
Brad
