IAT sensor + nitrous timing retard quesion..
Old 09-20-2004, 02:39 PM
7 Second Club
Phil99vette's Avatar
Default IAT sensor + nitrous timing retard quesion..
What resistor can I use inplace of the IAT sensor to simulate very hot conditions? I want to wire up a relay and once the nitrous comes online the relay will switch over to the resistor crossreferenced to the temp retard table so it pulls timing.
Phillip
Old 01-29-2008, 01:55 PM
pHEnomIC's Avatar
bump could be interesting.
Old 01-29-2008, 03:50 PM
Doc
Doc's Avatar
Low temps = high resistance (100k ohms @ -39 deg f)
High temps = low resistance (70 ohms @ 266 deg f)
I would use a varistor to vary the resistance as needed. That is, if I didn't have a custom operating system from EFI Live that allows me to pull timing and add fuel at the flip of a switch.
Old 01-29-2008, 04:20 PM
sprayjunkie's Avatar
This thread is 4 years old?!?!
Old 01-30-2008, 12:33 AM
SmaknaSS's Avatar
Man this is old. But anyway, Before we had custom operating system like the ones found in EFI Live, I used relay to electrically connect a potentiometer in place of the IAT sensor. I then adjusted the potentiometer to make the car think it was 145 Deg outside to make it pull timing.
Here is a like to some idea's on post #26.
https://ls1tech.com/forums/showthrea...=501965&page=2
Quick Reply: IAT sensor + nitrous timing retard quesion..
