how to fix bucking
Old 09-28-2004, 05:15 PM
luv2spd's Avatar
Default how to fix bucking
Hey guys. I just got my torquer cam installed and am starting to tune it. What all do i need to adjust to get my car to pull itself along in first without all the bucking? At the time my idle was at 825. I'm gonna try raising it to 900 and also increasing the idle air some more. Would this put me on the right track? thanks
Old 09-28-2004, 06:17 PM
HumpinSS's Avatar
reduce the ve table at 400-800-1200-1600 by 60-80-90-90
Also check www.ls1tuning.com and chech the idle forum
Old 09-28-2004, 06:23 PM
luv2spd's Avatar
I already did the 60-80-90.
Old 09-28-2004, 06:52 PM
HumpinSS's Avatar
Usually bucking is caused by a rich condition. So try decreasing a little more and see what happens
Old 09-28-2004, 07:22 PM
luv2spd's Avatar
Ok, thanks. I will try that this weekend and post the results!
Old 09-29-2004, 12:00 AM
P Mack's Avatar
I still had bucking after I lowered the ve table at low rpms, but when i hand smoothed the ve table in that area it seemed to help a whole lot.
Old 09-29-2004, 12:02 AM
luv2spd's Avatar
Could you post a screen of your ve or send it to me? thanks
Old 09-29-2004, 01:15 AM
P Mack's Avatar
It still needs a lot of work, especially at high MAP, which i can't even get to at this altitude (7000 ft). I think the sharp changes I had before in the lower rpms around 40-60 kpa was causing the bucking.
Old 09-29-2004, 01:22 AM
P Mack's Avatar
This is what I had before smoothing.
Old 09-29-2004, 02:42 AM
2MuchRiceMakesMeSick's Avatar
Combination of timing and a rich condition causes this. I am currently learning how/what to do to fix it.
Old 09-29-2004, 03:37 PM
P Mack's Avatar
Too much timing or too little timing? Or timing tables that aren't smooth? I have almost no bucking now but if i could get rid of it completely by tweaking timing that would be awesome.
Have any of you mafless guys noticed less bucking than when you had the maf?
Old 09-30-2004, 12:05 AM
The Dragon's Avatar
Reduce your timing ~3* from .08 to .32 in the offending rpm's in your timing tables. Might need a degree or two less.
Old 09-30-2004, 01:05 AM
luv2spd's Avatar
So I should try reducing the ve and cutting some timing?
Old 09-30-2004, 12:15 PM
luv2spd's Avatar
to the top
Old 10-01-2004, 06:35 PM
Let us know if that fixed it, ttt for now
Old 10-04-2004, 02:27 AM
The Dragon's Avatar
If you're asking if you should lean out your ve, than you need to log your car again and make sure your Lterms are where they need to be at part-throttle. Once your Lterms are in line, then modify your high/low octane tables as I posted.
Old 10-04-2004, 10:45 AM
luv2spd's Avatar
Well, I didn't have a whole lot of time to mess with it. I tried a tune where I leaned out the ve some more and pulled 3 deg. of timing from 1200 on down in the ho table. It almost seems like it bucked worse than it did before. On the histogram, all the low rpm regions indicate lean, but it still surges at start a little bit. It's worse with a cold start but it still surges a little with a warm start. I haven't done anything with my throttle blade yet. Would it make a difference if I opened that up some to get the iac down to a lower level? Also i have my running airflow at like 9.2. How do I know how far to raise that?
Old 10-04-2004, 11:39 AM
P Mack's Avatar
Open up your throttle blade based on your IAC counts. If you open it up until you see about 35 that is a good rule of thumb to keep it from surging, but each car seems to like a different number to get a good balance between surging and the cruise control effect.
Just make your desired airflow equal to what you see at idle. That's not really that important because the pcm learns how much airflow you need to sustain your idle speed regardless of what you set your desired airflow to. It will help if you unplug your battery or something cause it won't have to go as far to relearn the idle trims.
Old 10-04-2004, 03:01 PM
luv2spd's Avatar
I've heard that the ltrims don't mean much at idle. Or are you talking about the trims above idle speed? Also, do i lean out the first three columns until the surging goes away? I did like 55, 65, 75 and it still surges, but that may be b/c i haven't opened the tb blade as mentioned earlier. My trims look bad in the histogram. They are like 7-10 in the idle range. This would indicate lean, but i don't know if should go by those for idle a/f tuning? thanks for helping me out guys!
Old 10-04-2004, 03:07 PM
P Mack's Avatar
The throttle body should be the first thing you change in my opinion.
