Reality Check, PE = WOT only?
Old 10-27-2004, 11:03 PM
MelloYellow's Avatar
Default Reality Check, PE = WOT only?
Just a quick reality check.
Is PE Mode used during WOT only?
Also, if related could someone give me a quick refresher on open loop and closed loop definitions?
TIA!
Old 10-27-2004, 11:27 PM
P Mack's Avatar
Yes, PE is only used when the WOT threshold is passed, which is like 64% throttle at low rpms and 26% at high rpms.
Open loop means the pcm doesn't adjust fueling based on the o2 readings, closed loop means it does adjust.
Old 10-28-2004, 08:33 AM
Moderator
jimmyblue's Avatar
WOT means different things in different places.
There is a PE enable threshold %TPS and MAP.
TPS is as described. But the trans tables think
TPS is >94%. You can make it what you want.
Open loop fueling tables also enrich fueling on
a continuous MAP basis while PE enriches only
when TPS and MAP are satisfied, by RPM. I haven't
found any description of non-PE ways to enter
open loop mode dynamically (only "static",
temperature enable and like that).
Quick Reply: Reality Check, PE = WOT only?
