Will replacing knock sensors do any good?
Old 11-07-2004, 04:36 PM
V-10 Killer's Avatar
Default Will replacing knock sensors do any good?
I've spent all this year trying to tune out knock retard that I get typically around 4500 rpms (but very unpredictable). I currently have my timing at 4500 rpms and 0.64+g/cyl tuned down to 22 degrees, and still see 3.9 degrees of knock on occasion.
I have a '98 TA and have read that the '97 & '98 knock sensors can sometimes report false knock. If I order 2 more from GM, would that solve it, do you think?
Or are they likely the same batch number that I already have in my car?
I have the intake off now and could check on which connection type they are. I've heard that there's two different kinds.
Old 11-07-2004, 06:06 PM
Another_User's Avatar
Replacing the knock sensors *may* solve your problems. I tuned my false KR out with HPTuners v1.5 (thank goodness they gave me that option). Worked perfectly so far. I have never heard an audible ping in my car except maybe once or twice giving the car too much throttle at really low rpms.
Old 11-07-2004, 07:30 PM
LS1Tech Sponsor
Slowhawk's Avatar
I've replaced a few on 98 cars and some helped but some didn't.Like HP tuner,with edit you can tune out false KR. Also have found if you have a noisy drivetrain like torque arms(solid mount)ect the false KR might never go away.Those cars I delete the KR sensors.
Old 11-11-2004, 04:31 PM
Well, I pulled them out of my car, I'm going to try to replace them and see what happens. The number on the side of them was 10456222. They do have the orienting tabs on them.
Were these the questionable ones?
Old 11-12-2004, 10:12 AM
Yes. However there are differences between how the PCM uses them between 98s and the rest. Different values (the table is different in fact). So if you have HPTuners there may be a little more work to do.
Old 11-12-2004, 10:58 AM
tici's Avatar
Who can explain how to handle false knock with Edit?
My 98 LS1 has the typical problem... 3.8 KR!
Old 11-12-2004, 11:18 AM
With edit you need to raise the "noise floor". Do a search for that, if you don't find anything let us know.
Old 11-12-2004, 05:04 PM
tici's Avatar
"Noise level" is the magic word in many posts, but I haven't find any specific information. The stock setting is 1.7 what to do?
Some replace the 98 sensors, but not everyone has positive results.
Increase VE in that specific spot, reduce timing, increase PE... those are just a few of the suggestions I saw, but until now I haven't find the final cure for that.
I also built an adjustable desensitizer and it works, the question now is "what is a safe desensitation".
In my case reducing timing by 5-6* in the critical spots did help, but you can also feel the reduced power.
What next?
Old 11-29-2004, 11:05 AM
Well.....what the hell. I just threw 2 new knock sensors in the car. We'll just have to see what happens. If that doesn't fix it, I'm upgrading to HP Tuners anyway. I'll just have to fiddle with it in the spring
Old 12-01-2004, 07:56 AM
peterock98's Avatar
Are you still getting false knock after you changed the sensors?I also have a 98 .
Old 12-01-2004, 10:53 AM
I won't know until this spring. I just changed them 3 days ago, and the car's put away until early April
Old 12-01-2004, 01:27 PM
tici's Avatar
C'mon... a little ride
Old 12-01-2004, 03:56 PM
I'd really like to, but the car is half ripped apart right now.
Getting ready for a 12 bolt (and nitrous DS, and Spohn TQ arm) this winter.
Then I'm switching from my NOS 5177 kit to a dual stage NX kit
and switching from the LS6 to LS2 intake and 90mm TPIS TB, Z06 MAF and 85mm airlid
Needless to say the car won't even start right now
Old 12-01-2004, 04:56 PM
tici's Avatar
So many X-Mas gifts? Lucky guy!
This of the KR is really annoying: even if I know it is (should) be false I see it and I'm always afraid to mash the pedal.
Let us know if the new sensors work.
In April or whenever...
Thanks in advance!
Old 12-01-2004, 05:30 PM
<---fixed mine with HPTuners. No more false knock=
Old 12-01-2004, 05:52 PM
peterock98's Avatar
Old 12-02-2004, 12:55 AM
tici's Avatar
...and because you're such a nice guy you'll certainly tell us how...
Old 12-02-2004, 06:26 PM
I did. It's over on the HPTuners site.
http://www.hptuners.com/forum/YaBB.p...num=1099271043
Old 12-03-2004, 01:02 AM
tici's Avatar
"On the Knock Sensor Global Gain vs. MAP vs. Cyl, the table goes from all 4s to all 1s right at 65 kpa, I changed those 1s to 4s"
Is this in Edit Knock Retard / Attack vs RPM? Looks like...
So basically you are telling the PCM to wait 4 seconds before bothering about KR?
Talking about 98's: I had a lot (6-7) of KR at 1400-1600 rpm and 0.4-0.5 G/cyl (85-90 kpa MAP). The only solution was to reduce timing 8-10 degrees in that spot. The PCM did only removed 4-5 degrees but this was enough to get raid of KR (in thaht particular spot). Do you have (had) the same problem?
Old 12-03-2004, 11:57 AM
XpEdItIoUs's Avatar
how dose knock sound how would i know if im getting knock i have a 98 also this morning when i was going to the bank to deposit my check for more mods when i hit the gas and went above 3,000 rpms my engine sounded really loud kinda like if i used nitrous it was also really cold outside.
