Surging/Bucking: If you have HPTuners, then I have a change that may help!
Ok, I figured out that my car ran better in open loop than in closed loop (although pig rich). No surging or bucking (after I reset the LTFTs too). Then I re-enabled LTFTs and closed loop in the same drive. Plenty of surging and bucking to go around. So I just made a run with "Idle Proportional" fueling disabled. No bucking or surging. There was a bit of a throttle transition surge, but I am pretty sure that is because I have been messing with my Idle Airflow table. It looks like this may fix it (ready for another drive tomorrow!). Can somebody else try this out and see how it works for them?
When I went to open loop it helped my surging/bucking on deceleration but the surging I get when my torque converter locks is still there. Probably the fact that I have mine lock up at a low speed and in third gear as well as fourth doesn't help.
Yeah, it sucks that there are so many variables. I am running an SD tune, plus I have DFCO disabled, both of thos can affect the outcome too. I just hope when I take another drive tomorrow, that all is still well!
Any results?
P.S. I found that low rpm is really sensitive to trim variations on the VE table if your LTFTs are turned off.
Edit: I just took a drive. The thing was definitely running lean before turning off proportional idle. Now my VE table is falling into place better. At least all my research provided something useful finally.
Originally Posted by luv2spd
Another User- when you're done could you send me your file so i could look at your ve table. thanks
LS1Tech Sponsor
I'm surprised you guy's are having bucking problems with such small cams
What I've done and seen alot of is "over tuning" which means you make so many changes thaty it just doesn't get better.Sometimes I would just go back to a stock program and start over.
Are you guy's tuning starting from the idle?Meaning getting the idle squared away before any other changes? The reason I go there is because it can most definitly affect minor throttle input which causes bucking.A hanging idle will buck a car,expecially an A4 car. Some of the bigger Cam cars I do seem to like more timing in the lower rpm ranges,Some like less.
Just a few idea's for you guy's
Originally Posted by HumpinSS
So what exactly does the idle porportional tables do. I dont have bucking that would drive me crazy and i have a bigger cam 230/232 110 +4
Has anyone else tried this? I'll give it a shot once my HP Tuners unit gets here (hopefully this week). I'll try anything. I have to be over 75 MPH before I can use 6th gear because of the surging I get with the TSP 231/237 cam.
Originally Posted by wait4me
isnt the bucking you guys are talking about because your running airflow table or park position airflow tables are too high? that always fixes it for me???
we are all here to learn i think the bucking is because the computer is trying to get the rpms up to what it is requesting and it just cant because of the gear it is in is keeping it from doing what it wants, a car with a stall converter will just rev to what it is, but us m6 guys dont have the slipping like they do..
What about the bucking at lower rpm (<1300) and light throttle. I get that sometimes although its a lot better now than it used to be. Add or subtract timing? I've actually found that the bucking idling around in first got better when I added timing, but I'm not sure about the bucking at light throttle and rpm.
Originally Posted by Another_User
I'll do one better, I'll post it on the share board with all the rest of them. I may just post my latest revision up tonight. It's pretty much done now anyways.
This may be a stupid question but weres the share board Thanks Nathan
