ABS INOP...getting annoyed now...
Alright, i'm getting annoyed now.
I had an SES and ABS light on. It was not a TPS problem because the SES has turned itself off (it was a cat code) but the ABS INOP remains. I've driven it well over 350 miles and it's been over two weeks.
There are NO loose wires...
wtf.
It seems to be a common problem, but nobody i've asked knows how to fix it because, unfortunately for me, it's more than just an unplugged wire. I don't want to go to the dealer just to have them BS me either.
This all happened after I got the car dynoed.
Please help.
wtf.
Please help.
that means that the wheel sensors arent matching the same pulse from the front of the car to the rear.. having your car on the dyno makes the front tires not turning, and the rear are.. normally the car just resets after you turn it off and on then start driving again it sees the pulses are there and it turns back on.. but when they strapped the car on the dyno they could have pulled or cut the wheel sensors wiring in the rear, id check that if it dont go away. jes
Here is a pic of the back sensor connector.
And a pic of the wire...
Can any of you see anything that may be causing my ABS blues? Grounds? Anything?
BTW: Aftering testing my brakes again, they did in fact lock up......ABS is not working.
We had this problem on a car that we dynoed. It turned out that the connectors in the plug had been pulled back. They didnt come out, but they had pulled back far enough that they didnt make a good connection. I took a very small screw driver and pushed them back in and the problem was solved.
I have this same problem. Do you run different size tires in the front and the rear? The circumfrence of the tires have to be within 10% for the abs to work properly.
