I reset my TPS to 0 at idle, WOT shifts at 7200 RPM and only 80% TPS!!
Old 04-30-2005, 02:26 PM
99whitews6's Avatar
Default I reset my TPS to 0 at idle, WOT shifts at 7200 RPM and only 80% TPS!!
What gives?
Old 04-30-2005, 03:03 PM
Blacker's Avatar
Have you altered the stock throttlebody? My TB was 81% at WOT in stock form. If you look at the TB blade, the TB blade is not at full 90* angle with the gas pedal to the floor. I had to grind the hardstop and now have 100% at WOT. You may want to check for excess slack in the TB cable.
Old 04-30-2005, 03:15 PM
99whitews6's Avatar
well, I raised my Throttle set screw to 0.8 volts and then reset it to 0% TPS as idle. No physical things have been altered other than the set screw.
Old 04-30-2005, 03:51 PM
Blacker's Avatar
Check the throtle blade with the gas pedal to the floor. Make sure it is opening all the way.
Old 04-30-2005, 10:08 PM
99whitews6's Avatar
I THINK I MIGHT HAVE TO DRILL THE TB AND LOWER MY SET SCREW!!!
This is really getting to me now. I figured that I wasnt hitting 100% because my TPS voltage was to high at idle but I just checked my log from yesterday(havent touched tune or car) and it read 100% a couple time and a bunch in the 90's. I have been searching old threads for a couple hours now and there have been a bunch of people with the same TPS problems and the car not downshifting all the time when you put the pedal to the floor. Replacing the TPS never seemed to work for anyone. Im guessing that since I raised the set screw so high for idle there must be some slack in the throttle cable and also the computer is reading much higher than normal TPS% for shifting in general. This is probably also why my TC continuously locks and unlocks at 70 MPH. I HAVE NO IDEA WHAT TO DO! I also get a DTC for the TPS voltage every once and a while.
ANYONE HAVE A FIX?
Old 04-30-2005, 11:16 PM
Another_User's Avatar
Actually, I may have to agree with that. But I know I have cracked mine open a LOT, and my voltage is at .65v. Very peculiar. What RPM is your idle at? If you drill, don't go crazy. You should still try to control most of it with your set screw. Just drill a little bit, if you have to.
Old 04-30-2005, 11:48 PM
WAHUSKER's Avatar
In stock form our TBs do not open all the way. This is one of those "free mods". You have to grind the bump stop a little to make it open 100%. There was a sticky on "the other website" showing you how, might be instructions on ls1howto.com also. But it has nothing to do with the set screw. Mine is up, and mine reads 100%
If you do it, go slowly. You don't want the blade to go past full open or it can lock in that position.
Old 05-01-2005, 06:58 AM
Viper's Avatar
4.72 on a voltmeter is the max you want, over that and you're past 100%.
Old 05-01-2005, 08:18 AM
99whitews6's Avatar
1100 cold moving down to 900 at warm idle. I am going to try to move the Voltage down to 0.78 at idle and see if that helps. Anyone know how to get rid of slack in their TB cable due to raising the set screw?
Im also wondering if by raising the idle TPS voltage that it messes with the rest of the shifting parameters. Sometimes my cars shifts like 1 to 2 normal and then to 3 RIGHT AFTER 2. Its really weird.
Old 05-01-2005, 10:15 AM
99whitews6's Avatar
I just logged some idle in the car so I could get some more TPS voltage readings. I let it idle up to about ECT 165F and then quick slammed the gas and let off. It registered 100% TPS and 4.37 Volts. So this doesnt seem to be the problem. Its snowing here so Im not going to be taking it out for a drive till mid week.
I still dont understand when I did that burnout it shifted at 7200 and only 80%. Goofy!
Old 05-01-2005, 10:32 AM
Maybe your PCM did not properly reset after the set screw change.
Old 05-01-2005, 11:03 AM
99whitews6's Avatar
Thats just it, I dont think you can reset the TPS to Zero if the TPS voltage is above 0.8 volts. I think thats my problem. When I looked at my last idle log, the voltage dropped from 0.8 to 0.78 a couple of times and at the same time the TPS% went from 1 to 0.
Old 05-01-2005, 12:33 PM
I suppose it could be possible. That would mean the Holden PDF is wrong, which is possible I suppose. You should probably just very slightly enlarge the hole on your TB blade.
Old 05-01-2005, 02:19 PM
99whitews6's Avatar
If someone wants else could verify this I think it would be great information to know for the guys with the larger cams. Just raise your set screw to a voltage greater than or equal to 0.8 Volts as idle and try to reset the TPS% to zero.
