How to proper scale injector flow table for SVO 30# injectors
Old 06-13-2005, 09:51 AM
02 Pewter LS1's Avatar
Default How to proper scale injector flow table for SVO 30# injectors
I installed my new heads and Fast 90 intake with SVO 30# injectors and need to scale them to get me to the dyno. The car is running -10 on my LTFT's. My fuel pressure is around 62 psi with the Racetronix fuel pump.
Old 06-13-2005, 10:02 AM
1fastWS6's Avatar
36/28.8 = 1.25 will get you pretty close. Although 1.32 may be closer with the higher fuel pressure.
Old 06-13-2005, 10:11 AM
Sweet thanks. I will give this a shot.
Old 06-13-2005, 10:26 AM
7 Second Club
Phil99vette's Avatar
Use the calculator:
http://www.transamws6.net/HPTuners/injectors.xls
Input:
40
58
30
Phil
Old 06-13-2005, 10:34 AM
Originally Posted by Phil99vette
Use the calculator:
Input:
40
58
30
Phil
Thanks Phil this looks like it will work just fine I need to look at it more so I can understand this.
Old 06-13-2005, 10:38 AM
Moderator
jimmyblue's Avatar
30*sqrt({your 62}/{Ford's 40}) would be the
0-vacuum flow value for these injectors on your
fuel rail (is that 62PSI at WOT, or just 62PSI at
idle? You might want to set it for the higher-flow
pressure).
Take that calculated value, divide by the value in
the leftmost column of your IFR table and you will
get the scale factor to apply to the whole table.
Old 06-13-2005, 10:45 AM
pressure).
The 62 psi is at idle only. I need to make changes to the whole table or just the injector flow table only? Jim give me a call if you could need to ask you a few questions.
Old 06-13-2005, 12:19 PM
7 Second Club
Copy and paste, This is from a tune I am working on for an 00/AFR/LG G5x2/SVO 30#
4.551722751 4.580090468 4.608283562 4.636305218 4.664158527 4.691846487 4.719372008 4.746737916 4.773946956 4.801001794 4.827905024 4.854659165 4.88126667 4.907729923 4.934051245 4.960232896 4.986277075
Old 06-13-2005, 12:37 PM
Awesome thanks Phil.!!!!!!!!!!
Sent you a pm.
