code 1638 5v reference? what is it?
I just swapped a LS1 into a 97 firebird, changed everything and all harnesses. everythng works except the car idles crappy dies at times and trips the code 1638 for 5 volt reference? what does this mean?
car has ported heads and a 224/224 .581/.581 cam installed also.
it also has a misfire detected, and the AC pressure low (havnt filled it yet)
Im also using HP Tuner.
thanks.
thanks.
it is a 2000 LS1 but the harness and pcm is from a 99, i have a tune w/ the ve tables adjusted for a cam, and also tried the stock tune. doesnt make a diff. we took it for a drive, it kinda coughs and mis fires and has absolutley no power.
i'll look into the alternator. could it be something stupid that was over looked? we've double checked everything and all seems to be hooked up and working....that we know of.
misfire is unknown. it runs fine when its in neutral. it also has a 3800 stall and nothing tuned for it. while driving it stutters and wants to die when you let off the gas. plugs are new, wires seem in good cond. its not a steady mis. very eratic.
codes- engine misfire detected, AC low, and the 5v reference circuit 2
no other ones.
no other ones.
