startup spark correction, with a cam can you increase the numbers?
Old 06-23-2005, 07:50 PM
WS6FirebirdTA00's Avatar
Default startup spark correction, with a cam can you increase the numbers?
im having troubles on cold start up, the problem seems to be low timing, im getting 10-12* on cold starts and was wondering if with a cam i should take this table and increase all the numbers that are negative by about 2* or 3*?
Old 06-23-2005, 11:47 PM
technical's Avatar
How long does the timing stay at 10-12* before it increases to normal?
Old 06-24-2005, 04:55 AM
in the table it stays for about 70 seconds, would it be a good idea to add timing to this table like i had to do to the rest with the cam?
Old 06-24-2005, 05:38 AM
Checkmate's Avatar
I was having some surging problems.
Startup Spark Correction table. I cut all the timing reduction values in half for the first 10 seconds of startup. So if the reduction value was -10 it is now -5. It starts just like stock now, no surging.
I did nothing with the Startup Spark Correction Mult vs. Startup ECT table.
edit, sorry about the confusion this should clear it up.
Old 06-24-2005, 08:32 AM
multiplied the startup spark correction you multiplied by 0.5?
Old 06-24-2005, 08:39 AM
technical's Avatar
He said airflow so probably not.
What does you desired idle rpm table look like?
Old 06-24-2005, 08:45 AM
ive got it going from about 1075 at ~50*F down to 825 at operating temps, it will not alow me to reach the desired idle on cold start, and by cold start i mean engine is cool to the touch and has been sitting in the garage overnight
Old 06-24-2005, 08:47 AM
id like to know what checkmate did because that is what my car is doing, and only in cold open loop start. for about 7-10 sec the car will overshoot and then bog down really low and end up comming back up to about 100 rpm lower than where i want it to be, which is why i was thinking the timing could be keeping the motor from that?
any ideas?
Old 06-24-2005, 08:53 AM
Checkmate's Avatar
If I had my laptop in front of me I would post a screen shot. I can do this later if need be.
Old 06-24-2005, 10:49 AM
thanks man ill give it a shot when i get home
