HP tuners connection problem
Old 07-04-2005, 10:16 PM
99FormulaWs6's Avatar
Default HP tuners connection problem
I went to upload a new tune today and everytime I tried to connect it kept showing cable not found. After a few tries, I plugged into my truck and connected just fine. Tried the car again, nothing. What could this be?
Old 07-06-2005, 11:18 AM
WS6FirebirdTA00's Avatar
my serial cable is **** that came with it, i think some of the wires were loose in it cause if i jiggle it around it works. lots of other guys with the same problem
Old 07-06-2005, 12:12 PM
I don't think that is it, the cable works fine in my truck, and in my car, just not my buddies.
Old 07-06-2005, 12:34 PM
well i got mine to work after disconnecting and reconnecting it all and no matter what i did before that it wouldnt work. its worth trying at least. if his isnt connecting check his cig lighter fuse and make sure its not blown, and that he has no loose wires
Old 07-06-2005, 12:36 PM
bmfcamaro's Avatar
make sure scanner is not open
Old 07-06-2005, 02:22 PM
cook_dw's Avatar
Yeah what he said..
Old 07-06-2005, 03:43 PM
Scully's Avatar
what's up fellas? my car is the one that 99formulaws6 is trying to work with. i checked the fuse and the port and everything is fine. my buddies autotap reads it fine and also today i had a mechanic hook his laptop up to it that he uses to fix cars, it read it and told me what code my car was throwing. p1153 it just doesn't make any sense though, this has got 99 formulaws6 and me confused. hey 99formulaws6, if you find out anything or if you can get danny's software, call me. thanks for the help
Old 07-06-2005, 04:10 PM
FILE's Avatar
This is really weird. I had the same issue and it turned out to bew the cig lighter fuse. I replaced that and it was connect.
Old 07-06-2005, 05:04 PM
Scully just called and his lighter fuse was blown, so we're gonna try again. Cook, it wouldn't upload the program OR scan.
Old 07-06-2005, 05:08 PM
the cig fues is on the same line as the power for the obd 2, you learn this real fast doing inspections lol
Old 07-06-2005, 10:10 PM
Scully's Avatar
i went to 99formulaws6's house and everything worked this time. it is wierd how they have the cig fuse and the obd2 hooked together. thanks fellas and big thanks to formula99ws6.
