Mysterous flashing check engine light
I have a car that we're touching up the tune on and from time to time the check engine light flashes. Its a stock bottom end + magnacharger + alky. When your driving under very light load/cruising, the check engine light will flash about 6-10 times. If you quickly go to the code portion of the DIC there is no set code and I had a scanner on it and didnt throw a code there either. Any ideas?
Phil
Phil
Restricted User
Agree, if there is a misfire, you get the flashing SES, and if the SES doesnt set a DTC then either the limits are off, or otherwise not setting. Interesting enough, I also have a car I am working on, we put in the new CheaTR cam, and around 4500-6000 randomly, the SES will flash, after enuogh times it finally set with Misfire, but was immature, so cleared the log, and scanned again, no more issues after the next few runs.
Good luck with it Phil and post up, or pm me your findings please.
"All Motor 9 Second club member"
Phil I had the same problem after the install of my 244/612 cam. I just had to fill in the misfire tables with 32767 at the effected rpms. I had the idle rpm tables set already, but i had modif the lower cruise tables as well and now it's doing great. I left the mid/uppers as a back up for a real misfire issue. Mine would flash when I was cruising with light throttle or when I accelerated softly from an intersection. If it flashed , I could blip the throttle and it would clear temporarily. This indicated a designated rpm/load range false misfire.
I hope this helps. It is wierd since there is no code stored. Good luck!
