This may be a stupid question(LTFT&STFT).
I was talking to my buddy, who has a 99 Camaro. I told him I had been tuning my car(VE Tables) for almost a month, trying to get them perfect, he said what a waste of time. He said its not like you are going to gain any HP from doing that. Is he right? Will I gain any HP from tuning the VE tables?
I told him, my car feels a bit more powerful now that I am getting close to tuning the tables. He said its all in my mind.
Thanks,
Jason
Thanks,
Jason
I like to think of the VE tables as the foundation for the rest of your tuning. If you have the VE tables spot on, your car's actual AFR will be the same as the computer's commanded AFR. Once this is dialed in, any changes that you make to your PE table will produce the desired AFR so you can get your fueling perfect for max horsepower.
If there weren't gains to be made with tuning, there would be no tuners and no tuning software because there would be no market for it.
Thanks for the re-assurance.
Jason
WOT/PE modes are a derivative of the partial table, as the only thing we can measure with normal narrowband O2s is the partial throttle operation. So in a way, you must have this working perfect to have it switch to WOT operation correctly.
If you have a wideband, you can get lazy and just tune WOT with injectors, like most of the ******* 'pro tuners' do, but that is such a hack that it makes me cringe.
do your VE, set your PE, do your MAF, then go on a dyno and play with PE/timing till you get it right.
Restricted User
Jason, in reality you wont see any HP gains from VE tuning, since PE runs the dyno. However, with a fucked up VE, as mentioned you will have a hard time dialing in a constant PE. You will see better economy, and more responsiveness since the fueling is all dialed in. Good luck. I still need to do mine, but I am quickly becoming the master procrastinator.
I'm a big fan of having your VE dialed in perfect.
1. it tells you about the volumetric efficiency of the engine, so you actually see the effects of your mods on the system as a whole.
2. 99% of the time you are NOT WOT, thus you're on the partial throttle. Tune it, and your daily driver fun factor goes up. Most fbodies here are daily drivers, not dedicated track cars.
3. proper base (VE) makes derivatives (PE) run very well. I spent 5 months tuning on the street with narrowbands, and when I went to a dyno, I gained a whopping 6rwhp in 2.5hrs of tuning. talk about throwing away your money :/
