logging AFR with HPT
Old 08-21-2005, 08:18 AM
HellRaiser's Avatar
Default logging AFR with HPT
I have the LC-1 wideband setp. For some reason I can't logg my AFR with my HPT. When I go into scanner the narrow-band is the only thing highlight and it won't let me click on wideband. Is there something I need to do?
Old 08-21-2005, 12:33 PM
horist's Avatar
you need to use the correct cells... the wideband pid is added at the bottom below the standard PIDs
in the help file under VCM Scanner -> Scan -> EIO it shows which spots to use for each input and output
Old 08-21-2005, 12:44 PM
HellRaiser's Avatar
thanks.
Old 08-21-2005, 07:40 PM
HellRaiser's Avatar
OK I read about how you have to setup the wideband in one of the 4 inputs of the HPT but I don't see where you have to do it at.
I know how to get to the LC-1's 2 inputs, would I have to set that up to?
