Beta diagnostic - LS1Edit
Is anyone using this?
I downloadded it and can't seem to get it to work. I assuem you use your LS1Edit cable and that it is a standalone software program.
Is this correct/
What does it log and is it good or a piece of dung?
Is this correct/
Best diagnostic software
I need to do some diagnstic testing (Ltrims) to better tune my car with Edit.
I currently have OBD-2 by alex pepper. It is garbAGE becasue any results need to be cut and pasted to an MS Excel file.
Is there another software program that is easy to use and not costly?
Robert the scanner works fine and the exporting to excel is seamless.
Yep you use the cable. Hook it up, turn on the ignition and start the program.
I think where you may have gone astray is in the program setup. Follow the directions precisely. I think you need to load it in the same directory as LS1EDIT.
Engine Speed (RPM)
Long term fuel trims bank 1 and 2
Short Term fuel Trims bank 1 and 2
O2 sensors bank 1 and 2 (front only)
TPS position (percent)
Timing Advance
Knock Retard
IAT temp
Dynamic Cylinder Air
MAP sensor
Also of value:
MAF Sensor
Vehicle Speed
Injector Pulse width bank 1 and 2
Timing Advance
Knock Retard
IAT temp
MAP sensor
Also of value:
MAF Sensor
Vehicle Speed
Here is what it shows:
I did some logging over the weekend. Great data.
Time
Open/Closed Loop
Water Temp C
LTFT Cell B1
LTFT Cell B2
MAP in Kpa
RPM
Speed KPH
Spark Advance
Air Temp C
MAF in Gms/Sec
TPS in %
O2 B1 S1
O2 B2 S1
Fuel Trim Cell
Knock Retard
MAF Frequency
Inj. Msec B1
Inj. Msec B2
Gear
LTFT Avg. B1
LTFT Avg. B2
Gms/Cyl
Inj. B1 %
Inj. B2 %
Time
Open/Closed Loop
Water Temp C
LTFT Cell B1
LTFT Cell B2
MAP in Kpa
RPM
Speed KPH
Spark Advance
Air Temp C
MAF in Gms/Sec
TPS in %
O2 B1 S1
O2 B2 S1
Fuel Trim Cell
Knock Retard
MAF Frequency
Inj. Msec B1
Inj. Msec B2
Gear
LTFT Avg. B1
LTFT Avg. B2
Gms/Cyl
Inj. B1 %
Inj. B2 %
Not bad at all!
How many lines / data per second is it able to record?
I actually use Atap on my Palm and it's pretty slow: if I record 12 parameters at time (the max that it can do) it will write a line every 0.5 sec.
It works but for certain things it's too slow.
Stefano
Stefano
