LSX install, +25 LTFT
Originally Posted by MeentSS02
Yes...you have most definitely affected the VE of the engine.
Off topic slightly, but do you have any numbers from that setup (the AFRs with the LS6 cam)? And are you using the AFR-supplied valve springs?
We just finished the install around 1 in the morning last night and put in a basic tune on it and ran a quick idle scan and yes, we're running the AFR valve springs.
Originally Posted by SMOKINV8
Holy lean... That combo looks like it would take a little more fuel at idle, but wow... Must be the small cam combined with the high velocity AFR's?
LOL, That's what I said. I told my friend to go with a bigger cam , but he wants to see what it will run first.
Kleeborp the Moderator™
I'm just interested to hear the numbers after seeing Z06s put down 410+ with just the AFR heads.
Originally Posted by Billiumss
You have a very bad intake leak. Unmetered air is getting in somehow/somewhere
I didn't want to hear that. We did hear a leak and found that we forgot to put the brake booster hose back on. When that happened the STFT were at +35 When we hooked it back on STFT 0 to -3,but LTFT +25. I guess we're going to try a little VE tuning and see if that changes things and if that doesn't work, we'll just have to reinstall the intake.
