specific SD tuning questions
I know this topic comes up a lot in this section but I cant find answers to my specific questions by searching. First I want to ask if I have all of the settings correct for SD tuning: high octane copied to low octane if pre-'01, MAF fail frequency set to 0. Is that it or is there more settings?
secondly, after each VE workover and when starting a new scan, should LTFT's be reset?
Third, after SD tuning has been completed what settings are needed to finalize the tune to run SD all of the time? I thought I read that LTFT learn needs to be turned off after initial LTFT and VE tuning....is that correct?
I also set the PE Enrichment V8 Mult vs RPM to all 1's to disable PE Mode. You should reset the ltrims so you don't average the new values with the old values. Also, it will take some driving to cover as many cells as possible. Once you get the VE table to your liking, you can leave it SD mode. Only thing you would have to do is dial in the PE Enrichment. The only time you would turn off the ltrims is during open loop tuning with a wideband.
Originally Posted by TAQuickness
Take a look at the link in my sig.
putting all 1's in PE doesnt Disable it...
it just makes the multiplier = 1
yout trims lock when you go into PE...so its not learning..its just going off of the values already in the computer...
to diable PE you need to set the PE enable MAP value to 640..or really any number above a value that your car will hit
If you set the table to 1.000, the car will not go into PE. So, it is disabling it. I have been doing this with the open loop values at 1.13 and it is hitting 13.0 across the board in the high rpm's.
the car will still go into pe but since you have an AFR that is richer in the OLFA table the PCM chooses that one instead....
LS1TECH Sponsor
