Any bad things about running 160* degree t-stat?
#41
Originally Posted by The Rookie
So I am assuming that I should go with the 160 stat?? Expecially here in the hot *** state of Texas?
a 160* thermostat doesn't mean the car runs 160* .... it just opens up sooner to let coolant intot he engine....
as far as i'm concerned... the only reason to not use a 160* thermostat is if you're in a place where it gets cold and you have to drive the car (takes longer to get heat) ..... but the simple fix for that is..... swap thermostats for winter hehe (that's what I'm doing w/my GTP)
#43
ive heard from a tuner modder guy says that ls1 is good motor but they have to
run hot or they dont seal good,lot of blow by like a smoke stack if not hot. he told me
run 195 or 180 with the fans on top of that.
#45
Originally Posted by horist
I have a 160 in my car, coolant temps are generally between 180 and 190 ... so no probs w/the 160
I run a 160 in my GTP too... going to be a cold winter heh
If you are running big compression (my Static/DCR are 11.05/8.3), and higher timing you are going to want those temps to control knock.
FYI: I still get 29-30.5mpg on the interstate
