car throwing many codes.........
ok my car has been running like ****. i have had problems before and it was plug wires. no big deal. today i checked all the wires and one was off a little bit. so i am thinking theres the culprit so i push it back on and take it for a test drive. car drives fine. so then i am thinking ok a quick and easy fix. later on today i take the car out and it runs like **** just like it has been. i am like what the ****? so i take it to advance to get a diagnostics test. throws these codes:
P0155 -O2 sensor heater, circuit malfunction (bank 2 sensor 1)
P0300- Random/multiple cylinder misfire detected.
P0410- secondary air injection system malfunction
P0412- secondary air injection valve A malfunction
P1153- Manufacturer control. fuel air metering.
ok so i know the air injection cause i got rid of it with header install. the misfire is probably a loose plug wire even though i have checked the wires like 100 times since yesterday. the P1153 i am not sure about and the P0155 is that just a bad 02? i have sims in the back and ext. in the front, which one is this and what do i have to do?
thanks.
chris
thanks.
chris
Originally Posted by SSoofast
Bank 2 sensor1== passenger side front sensor--heater code is usually a bad sensor-replace it.
If the O2 is dead and giving bad readings it can cause the car to run like crap. The car running like crap could cause a missfire code. Also, The front sensors are the ones used to adjust fueling.
I really dont have any advice on how to help But I am getting similar problems. I threw a P0155. I have not thrown a misfire, but my missfire detection is turned off. I have gotten a loose spark plug wire and then messed with them and the truck ran fine. I am going to replace my wires and then see what happens.
