Another lame look at my tune/log thread.
I've got my LTFT's dialed in pretty good, A/F ratios as good as they're going to get with narrowband o2's, and I think most of the knock is removed. My timing table is UGLY, and my primary VE vs rpm is pretty ugly too, but bearable. The throttle response is good, and it pulls alright. My problem is when I try to turn my MAF back on, I can't get it calibrated right. I tried the spreadsheets but, it's just not working. I've logged 40+ minutes of MAF hz and Dynamic Airflow, but the spreadsheet didn't do it for me. When i turned the MAF back on my LTFT's went WAY WAY rich, like -10 to -14. Right now everything is between +-2. Here's my tune and log, ANY ANY ANY input at all is really appreciated. You guy's have all been helpful, and I'm learning alot.
On another note, my idle sometimes studders when I come to a stop as well. Dies every once in awhile, and ideas on that? I got my idle set around 900, my IAC steps fairly low like 40 ish once the cars warm, just no luck.
Thanks again:
http://verydrunk.info/hpt/2-6-2006.bin
http://verydrunk.info/hpt/2-6-2006-22.20DriveTowork.hpl
Is it normal to tap 140 on the way to work?
Anyhow, thanks again.
Mike
Thanks again:
Mike
if your maf screws it up while SD is normal then it's just maf. if your maf calibrations keep failing, it means your maf is either broken, or your air filter is dirty and throws so many bad reads into the sample that it throws of averages. clean your filter, post some logs with maf freq and dynair.
other than that, logs/tune looks clean
Here's a log with MAf hz, and Dyn Airflow:
http://verydrunk.info/hpt/2-7-2006-gettinggasMAF.hpl
I'm going to pop the numbers into the spread sheet, and hope for the best again.
Mike
Mike
Question for Red...Supra regarding Inj Flow rate
I was viewing the spreadsheet that you have in your post and I noticed that the flow rate increases as the manifold vacuum decreases which seems correct. When I look at my stock tune (ls1 edit) for my z06 it is just the opposite. The flow in gm/sec decreases as the vacuum decreases. Am I stupid or what? By the way. I appreciate the info in your posts. Thanks.
Much much better this time. Within -2 to +4. I suspect if I fed the spreadsheet more maf hz and dyn airflow, I'd be alot closer too. Thanks RedHardsupra, your work is really appreciated, and so is your input.
Mike
Mike
Guess that should of been obvious to me. Thanks for helping me out, I really appreciate it. Am I crazy, or is my timing sort of low? My tables look kind of funky, because I've had to take out certain places. Should I try smoothing it? My cam does have +4 degrees in it. But I see alot of guys running crazy timing? I'm running good gas, and see knock in certain places, as you can see by my tune, and the random dips in the graph. Should I start over with my stock timing, I tried with z06 timing? Just curious.
Thanks again!
Thanks again!
