Getting started with HP Tuners??
So do I need to plug into my car and upload the stock tune, then adjust the peramiters from there? I'm a total newb. Not sure exactly how to get started.
I've got the program installed on my p/c. Downloaded a members bin. to look at. Probably only confused me more.
Little help please
Little help please
That helps , is there a specific process.
Example:
1) turn on computer and open hp tuners???
2) plug in to diagnostic port???
3) turn key on.???
Does the car need to be running?
C'mon guys hook the tuning newb up!
Example:
3) turn key on.???
^^^^ F1 and all your questions will be answered
also
http://www.hptuners.com/help/
look under getting started
I would suggest reading through the help manual (yea it gets dry but it's useful) first before changing any parameters... they've added so much info to it, it's crazy (I Just reprinted it the other day to read through again)
But basically... key in run position, wait about 10 seconds for PCM to "boot up", on laptop open editor, go to flash-> Read PCM, once done reading (< 2 mins) it'll prompt you to save it.. then it'll open it up
Since you're a 98, keep in mind you should ONLY use your file or derivatives thereof (modifications of your stock file) ... also always use the write calibration only when reflashing
also
Multiple computers and operating system?
Yah... I got it .
Since it's a 98..... If I'm using a two different computers (pc for editing and laptop for downloading, data logging, etc. [don't actually have a laptop yet]) do I need to make sure both computers have the same operating system? I'm assuming YES???
Thanks!!!!
Thanks!!!!
Originally Posted by foff667
nope...i have my home computer with xp work computer with win xp pro, one laptop with xp & one laptop with win 2k...all work fine for me.
Originally Posted by ashade98
Is yours a 98? They're more sensitive
Only thing that matters is that you use the file you downloaded from your PCM for all your editing and writing/flashing
I'm already learning. Thanks for the help guys (Horist)
Originally Posted by horist
The computer (your PC) OS doesn't matter
