OBDII Tuning for removal of rear o2's and AIR system
Old 04-08-2006, 05:45 PM
gillbot's Avatar
Default OBDII Tuning for removal of rear o2's and AIR system
There used to be a guide or "how to" that showed which codes needed turned off to pass OBDII emissions testing after you remove the rear O2's and AIR system but I can't seem to find it anywhere. Anyone know where it is or what codes need turned off?
Old 04-08-2006, 05:49 PM
Shallow Bay's Avatar
What program are you using to remove these codes?
Hopefully this will help
Old 04-08-2006, 05:55 PM
gillbot's Avatar
Edit. There used to be a "how to" with a list of all the codes and pictures, etc in a forum thread but I seemed to have lost the link.
Thanks!
Old 04-08-2006, 06:28 PM
LS1TECH Sponsor
foff667's Avatar
Thanks!
https://ls1tech.com/forums/pcm-diagnostics-tuning/287094-read-me-first-tuning-docs-ve-maf-ses-lights-faqs-more-01-31-07-a.html
Old 04-08-2006, 07:51 PM
gillbot's Avatar
I looked over that, show me where it is because I can't find it there.
Edit, the one posted above works perfect. Thank for the link: http://bowlingss.com/Removing%20Air_...%20Ls1Edit.htm
Old 04-08-2006, 08:15 PM
LS1TECH Sponsor
foff667's Avatar
duh i couldve told you that but apparently it wasnt good enough so i posted a link to the tuning 101 doc which has teh same info http://www.transamws6.net/HPTuners/ls1tuninginfo.doc heres a direct link to that though since apparently i didnt get you close enough
Old 04-08-2006, 08:20 PM
gillbot's Avatar
That's for HP tuners, I'm using edit but thanks for the link none the less! At least it has the DTC's that need removed and that will help.
Old 04-09-2006, 04:25 PM
gillbot's Avatar
I fonally found the original thread I was looking for: http://www.ls2.com/forums/showthread...threadid=17747
