hot starts suck after tune.tuner says he cant fix it
when i had my 346 tuned with my heads @cam it ran perfect and made 430 rwhp.so i built my 383 and went with bigger cam and the car would still crank and idle perfect with the same tune.but i had it tuned far the 383 trying to get all the power i could out of it .it made good power it made 490 rwhp but when i got back home and started it up the hot starts suck!it will idle at 500 rpm far aminute then it will idle up at normal rpm .so i took the car back to the tuner and he said the pcm is giving the car 20 to 30% more fuel at idle so he said replace the o2 sensors and i did with no luck checked far vacume leaks and exhaust leaks but the car still try to add more fuel at idle he said that there was something else is wrong not the tune. but it never did it untill he tuned far the new moter .the only thing i know he did was take out some timing far the raised compression but he said that has nothing to do with the problem does any body have any idea what problem might be . by the the way cold starts r fine but the hot starts r driving me crazy please help
If the problem is during initial open loop then crank and main VE tables may be too high around idle area.. typical for large cams. Added fuel during closed loop could be a sensor problem but it does not match well with good cold - bad hot start.
Make sure that your fuel system holds some fuel pressure for at least 20 minutes after turning your engine off when at operating temp? Some defective fuel pumps or regulators leak down fuel pressure too soon thus the fuel will boil in the hot fuel rails. This will cause a hard start and/or will idle too lean for several minutes until all of the fuel vapor caused from boiling in the rail and lines are purged out.
you know, MAF isn't the source of all evil, it's just a measuring device afterall. does you having a thermometer screw up the weather?
granted, it's a device that's in a way of airflow, but considering all the other bottlenecks it isn't so bad. now reversion is a proper thing to complain about.
My vote is Cranking VE. I had a similar problem. My idle VE% was/is about 25% and stock VE%, at the same RPM/kPa values, was/is around 65% - big difference.
I rescaled the Cranking VE to reflect the new VE table. Helped a lot with the hot starts.
Originally Posted by SMOKINV8
You can't be serious...
Originally Posted by warrenss
is their a downfall to not having a maf? will it make it drink more gas?more info please
The need to retune when weather/conditions are different.
A loss of a low octane spark table (safety measure).
That's about it.
Tuned right, they both seem to make the same power, but tuning for a MAF is more difficult than just deleting it. (so I've found)
