Transmission log
Transmission log
I went and did a log to see if my tranny is going out or is it my tune. Sometimes I bump the limiter and sometimes I don't and when I say bump, I mean it doesn't go bang, bang. It hangs there until I let off and then shifts. Anyway, I logged TCC slip speed, trans output, trans input and trans gear. Am I missing anything? Tell me what I'm looking for. What's good what's bad.
Honestly, I don't know what to log, but what is your shift speed/rpm set at? I think its safe to say that if you are normally shifting at 6200 (set at that rpm for example) but your bumping at 6600 (for example) every now and then, then likely your tranny is slipping (either low fluid or its on its way out).
