Vinci Tuner
Old 05-05-2006, 09:31 PM
senicalj4579's Avatar
Default Vinci Tuner
I just got my Vinci tuner today. They wasted no time getting it to me
I set the tune need to high performance stock cam,and both trans.features to performance. The shifts are very tight. When the car shifts into 2nd it actually throws my head back to the seat and spins tire.
Also, I noticed with the high performance stock cam tune the idle went down a little and it apears to be a little more quieter when cruising on the highway.
I'm trying to find out if i need to do anything with the power enrichment,shift spark advance,and increase engine idle rpm considering the mods i have. Does anybody have any info on these? Thanks, Joe
Old 05-06-2006, 08:49 AM
mrr23's Avatar
without having a wideband or on a dyno, it's a guess if you need more/less fuel/timing. you can try each one individually and drive it to see if you 'feel' any difference. you can try the different cam tunes to see how they work with the mods you have. back when i had most bolt-ons and heads with stock cam on the wife's car, i ended up with cam #3 for the tune.
Old 05-06-2006, 01:21 PM
hey whats up, why were you in cam #3 tune without a cam? was it the heads that put you in#3? if so,what in the world do you do when you put a cam in along with those heads and other mods? when i mod my car more i want to follow the guidlines for the tuner. how acurate do you think these tunes really are? thanks, joe
Old 05-06-2006, 01:24 PM
mrr23's Avatar
because that particular tune did what was needed. the tunes are a starting point for a cam in that range. then you play around with it from there. you may need to use a different cam #tune to work the best. that's what's good about this tuner. the tunes are super accurate. they get you close. then, you modify from there.
Old 05-06-2006, 02:03 PM
so far i think the tuner is great. everyone says to get a full tuning suit but i dont have time for that right now. the car is running good right now but i think i'll play with the power enrichment a little and maybee idle. thanks for the info;i'm sure i'll have more quistions in the future. i'm all phyced out about getting a cam now
Old 05-06-2006, 09:39 PM
navyblueSS's Avatar
I also have the Vinci Tuner and love it. In before and after drag strip testing et dropped over 3 tenths and car gained 3 mph. I later added +10% spark advance and picked up another 5 hundreths.
Old 05-06-2006, 11:35 PM
what tune are you running on?
Old 05-07-2006, 12:04 AM
navyblueSS's Avatar
Hi-Performance w/Stock Cam. I just installed Pacesetter longtubes and TSP ORY so I plan on trying out the power enrichment feature the next time I am at the track.
Old 05-07-2006, 12:07 AM
keep us updated on the #s you come up with.i have long tubes and other mods also. i'm going to be playing around with the enrichment feature as well.
congrats about being in the 12's.
Old 05-07-2006, 12:12 AM
navyblueSS's Avatar
Thanks. I appreciate it. I'm hoping to make it to the track next Friday. I will post results.
Old 05-07-2006, 12:15 AM
did you notice after you programed your car that the idle went down a little? if so did you ad to the idle rpms? mine went down like 100-150 rpms.
Old 05-07-2006, 12:21 AM
navyblueSS's Avatar
No, I didn't notice a change in idle rpms.
