Year of PC change on F-Bodies
I hear of 98 computers not as tune friendly resulting in less rwhp/tq numbers is this true?
Does the 2000 model year have the better pcm?
What year did they change?
thanks , cws T/A
thanks , cws T/A
LS1TECH Sponsor
according to hptuners compare there are ~67 different tables from the 98 to 99 computer including everything from VE, PE, IFR, IDLE, spark advance, TM...pretty much everything is at least slightly different. From 99 to 00 there were 37 differences including VE, Idle, spark advance. From 00 to 01 there were 97 differences and from 01 to 02 only 6 differences. So yes there are changes from year to year.
Restricted User
Originally Posted by cws T/A
Also can the pcm be switched from 98 to 2002 or is that when the sh&* hits the fan
There is no performance difference to speak off so it would seem to be pointless. It would be easier and cheaper to switch to a custom OS from someone like HPTuners or EFIlive.
1998-1999 67 Changes
1999-2000 37 Changes
2000-2001 97 Changes
2001-2002 06 Changes
207 Changes From 1998 to 2002
Is this Gm upgrading the Pc or Hp tuners upgrading their software?
Originally Posted by 98Z28CobraKiller
I believe that you would have to switch the harness and the gage cluster. Major undertaking which involves taking the dash apart.
Not sure on the gage cluster. I do know that on the 98 gage clusters the oil press, coolant temp, get their inputs directly from the sensors as opposed to the data bus on newer cars.
Don't know if the fuel tank will be needed to be swapped for the gage cluster to read right like others who have done v-6 or lt-1 to ls1 swaps. Maybe Magnus or etc. could chime in on that.
Thats great Doc do share the swap As far as dash removal Ive done it on other cars so that would nt be a problem , once you get the small peices out of the way , gas tank swap couldnt the sending unit be changed or rewired if not a whole tank swap to a newer model should work . keep the info coming
