lc1 help. can use lm programmer, but wont connect w/ log works2
Im using a USB to serial convertor but ive never had a problem w/ my LM1 or HPT. I can log and use LM programmer w/o a problem. I close LM programmer and try to open Log works 2 and I get
LogWorks2
No real time data detected. Check serial port and connections. Note, you MUST use 'Download LM-1 Log' from the File menu instead of a real time connection if operating in 9V battery mode.
OK
Any ideas? Thanks
Dave
LogWorks2
OK
Any ideas? Thanks
Dave
Moderator
I have had the exact same problem, no good solution from
the Innovate web discussion board. LM-1 came with no
"termination" stuff that I could see, and worked fine with
the original software & firmware but LogWorks2.0 is just
not interested in playing. I reverted to the original on my
old laptop, haven't gotten around to it on the new one.
Originally Posted by xaon
have the terminator plugged in? Terminator -> IN, Serial Adapter cable -> OUT
Dave
Originally Posted by Black02SS
Try and turn the key to the run position with the HPT cable plugged into the car and see if it will connect. I assume your LC1 is connected to the cable.
Dave
Dave
