Those using LC-1 what is your response speed?
Old 05-07-2006, 02:51 PM
MSGHUFF's Avatar
Default Those using LC-1 what is your response speed?
I was wondering what most of you are setting your response speed to when using your LC-1 for data logging? does the 1/12 or 1/6 setting smooth and slow down the logged AFR out to much to be useful?
Old 05-07-2006, 04:09 PM
joecar's Avatar
1/3 otherwise I found it to be too wiggley.
Old 05-07-2006, 04:29 PM
MSGHUFF's Avatar
Is this what you used when you ran the autoVe? Mine is a little wiggly too... Thanks
Old 05-07-2006, 04:30 PM
HumpinSS's Avatar
i use 1/12 or 1/6 cant remember at the moment
Old 05-07-2006, 06:04 PM
Kleeborp the Moderator™
MeentSS02's Avatar
1/12th here, but I scan at 40 frames per second for VE tuning...
Old 05-08-2006, 02:18 AM
joecar's Avatar
Yes with Auto VE and everything else.
How do you get 40 frames/sec, I'd like to do this...?
Old 05-08-2006, 08:39 AM
MeentSS02's Avatar
I only log the absolute bare minimum...like 4 PIDs or something (RPMs, KR, MAP, commanded AFR, and the wideband [since it doesn't count against the PID count]). Logging 6 bytes or less with HPT increases your resolution to 40 frames/second.
Old 05-08-2006, 09:32 AM
SideStep's Avatar
Do the same myself...
