DTC on 1998 Trans Am!
Old 07-07-2006, 05:47 AM
superj's Avatar
Default DTC on 1998 Trans Am!
Hi!
I am new to this forum and would like to know how I can access the DTC codes of a 1998 Pontiac Trans Am.
Is there a way to access it like on a Corvette, or do I have to use an additional hardware?
Thanks a lot.
SJ
Old 07-07-2006, 06:16 AM
horist's Avatar
you need a code scanner.. autozone will read it for free
Old 07-07-2006, 06:57 AM
superj's Avatar
thanks a lot. do you now a cheap scanner solution?
Old 07-07-2006, 07:48 AM
Doc
Doc's Avatar
Is free not cheap enough?
Old 07-07-2006, 11:17 AM
2001NBMZ28's Avatar
If you want to buy a cheap OBDII reader harbor freight sells one for around $50?
