whats a good 85mm MAF...not slp?
Old 07-19-2006, 09:08 PM
violator6090's Avatar
Default whats a good 85mm MAF...not slp?
whats a good non overpriced 85mm MAF. hearing some bad things about SLP's so what else is good in that price range?
Old 07-19-2006, 09:10 PM
bad6as's Avatar
the stock one off a c5 z06 im prety sure is 85mm
Old 07-19-2006, 09:31 PM
horist's Avatar
the stock 85mm LS6 MAF requires PCM reprogramming FYI
I would just stick w/the stock MAF... it does its job and it does it great, screen and all
Old 07-19-2006, 10:02 PM
Gary Z's Avatar
His sig says FAST 90/90 coming soon so programming can't be far behind. I recommend the stock 2001 LS6 MAF sensor (GM 25318411) which has a screen.
Old 07-19-2006, 11:58 PM
horist's Avatar
^^^ good point... didn't notice that
1 thing to keep in mind:
most lids are 78mm out
into a maf that's 85mm
Fast 90 TB is 90mm (stock TB is 78mm)
and into an intake manifold that's 90mm (stock is 78mm I believe)
unless you run a 90mm pipe w/out airbox and MAF (SD) you're experiencing a restriction......
Old 07-20-2006, 12:29 AM
qwikz28's Avatar
how about a 85mm lid - 85mm MAF - 90mm TB - 90mm intake
minimal restrictions for a nice free flowing intake system (only hard part being finding a 85mm lid)
Old 07-20-2006, 04:33 AM
^^^^^^ exactly what i was planning on. thanks ill look into gm ls6 MAF
Old 07-20-2006, 08:57 AM
DrkPhx's Avatar
That's what I run. I bought a used 2001 ZO6 maf on corvetteforum for $50. I did desrceen it.
Old 07-20-2006, 03:05 PM
qwikz28's Avatar
how did you go about tuning? did you tune with a stock MAF and then swapped in the LS6 or vice versa?
Old 07-20-2006, 11:22 PM
DrkPhx's Avatar
No. I tuned the car with the ZO6 MAF using the ZO6 MAF table.
Old 07-20-2006, 11:47 PM
qwikz28's Avatar
cool thanks man
Old 07-21-2006, 11:30 AM
Viper's Avatar
I've got the PACE LS6 MAF from 2002, no screen, works well for my mods.
Old 07-21-2006, 11:41 AM
ringram's Avatar
Or depending on your tuning save your cash and go mafless.
Old 07-21-2006, 04:04 PM
well i bought a 85mm MAF off an 04 z06 i plan on getting 90/90 setup and than dyno tuning real soon
