LS2 Throttle Body--88% open = max?
Question regarding the drive-by-wire throttle bodies:
When logging I noticed that when I go WOT, the scanner is detecting the throttle at 88% open. Additionally, when I let off the gas, 'closed' position is interpreted as 19%. Is there any way to calibrate the ETC?
TIA...
-Jason
TIA...
-Jason
Originally Posted by foff667
from what i understand GM interperts TPS position differently...as far as close position goes you have ETC and no IAC so the TP is partially open to keep your car idling as far as I know.
Originally Posted by Black02SS
Man, where have you been hiding?? I haven't seen you post in awhile now. Good to see you again.
