402ci 242/250 112 60# Motrons Drivability Issues
Having Drivability issues, car stumbles and hesitates when being driven under 2000 RPM. Engine sometimes races from 1000-1500 up and down several times then levels out at 1000. Very hard to get going from a stop, you have to slip the clutch out pretty hard.
Heres a list of what is in my 01 C5 Coupe...
-LS2 Block w/ ARP main studs.
-Lunati Non-Twist 4.000" Stroke Crankshaft
-Callies Compstar 6.125" Forged 4340 Rods.
-Diamond Forged Pistons 4.000"
-Comp Cam 242/250, 112 .600 Lift
-Morel Lifters
-Rollmaster Double Roller LS2 Chain.
-AFR 225 Heads CNC'd w/ Hollowstem valves, Upgraded Springs, 65cc chambers. Flow 316/238 at .600 lift
-ARP LS2 Head Bolts.
-Cometic Head Gaskets .051
-Hardened Race Bearings.
-Heavily Ported LS6 Oil Pump and Shimmed Up for Max Pressure.
-FAST 90mm Intake (Ported by Tony Mamo)
-LS2 TB (Also done by Tony Mamo)
-MSD Wires
-Vararam Air Intake
-Stainless Works 1-7/8 Headers w/ 3" X-Pipe
-McLeod Street Twin Clutch
-McLeod Aluminum Flywheel
-RPM T-56 Transmission
-3.90 Differential w/ all internal goodies
- 60# Motrons
Dyno was done on Drag Radials and they only did a few pulls on it. It was on a Dynojet, it started getting late and they said the car was too loud they didnt want to do any more pulls until tomorrow. Engine was built by SLED28
515 RWHP 480 RWTQ
New Numbers....
520 RWHP 484 TRWQ
-Morel Lifters
-MSD Wires
-Vararam Air Intake
- 60# Motrons
515 RWHP 480 RWTQ
New Numbers....
520 RWHP 484 TRWQ
Originally Posted by SLED28
I think the 60's are too big? Maybe some 42's would help down low?
Restricted User
Don't feel so bad. atleast you aren't alone. I have almost the same exact setup (including the injectors) and have the same surging problem in the range that you mentioned. I have been fighting it for some time. Looking like the injectors have to go. If you have the means to try going to a smaller injector w/o having to pay to see, please post your results so that I can follow suit. Good luck.
I agree with what everyone else is saying....those 60lber's are definitely too big.
Some other things you should look into is your Spark timing table in the idle rpm ranges. If your spark isn't where the engine likes for idle conditions, then you'll see the problems you're having.
You'll also want to check on your VE table at idle as well...if its not dead nuts on, you'll be having the same problems as well.
What conditions are you seeing during these bad surgings? Is it running rich/lean? Whats your IAC count at idle?
If you can get an EFILive file, i can take a good look for you!
Hope you love that engine...it looks like a brute!! SLED28 knows how to build
Best,
Adrian
Best,
Adrian
Restricted User
I'm not sure about Cannons but my VE table is right on 0 at idle and in the surging area when looking at averages. If I log the last time I hit the cell, it is slightly lean (positive AFR error) when in the surging cells while it is surging. I am using a wideband. My IAC counts at idle are around 30 after I am at 180 temp. Using HPTuners.
Restricted User
Originally Posted by NicD
60lb injectors are definately not too big, you just need to have it tuned properly. 60lb injectors work just fine on stock displacement barely modified engines let alone a hopped up 402.
7 Second Club
Originally Posted by 98Z28CobraKiller
Are you using them? If so, can I get a look at your IFR and offset tables? I have the VE dialed in pretty good. I used the IFR from Redhardsupras spreadsheet. No one has the offset info that is willing to share.
Restricted User
Nic and Fig,
Could I get a peak at your tunes? bellos98@yahoo.com
I am at my wits end with this thing and am considering putting the stock injectors and cam back in the car and it will be your fault J/K.
Regards
Regards
with a cam that big I would have about 30 degrees of timing at those rpms and at idle. Without a wideband and a scan tool your going to be shooting in the dark alot. Invest in a wideband, it will make your life much easier.
7 Second Club
Restricted User
Restricted User
Sorry, I do this type of stuff for money so I don't just give out tunes but I will give you advice to get you pointed in the right direction. Honestly your biggest problem is probably the 90mm TB and the tune, you have NW so it's the lesser of the evils but that isn't saying much.
Originally Posted by Cannons
What kind of times u turning?
Well right now im have the hardest time dialing in the suspension. But no excuses the best ive run right now is 11.1 @126 1.63 60ft and this was done in 88 degree weather. My car also weights in at a tad over 3800lbs with me in it (drag setup) no weight removal other than a bmr k member.
