o2 sensor question
o2 sensor question
have a 01 camaro bc4 that has the check engine light on.......took it to auto zone and they told me i had a bad o2 sensor ....said it was the one before the cat. coverter........well...when i look on the auto zone website.....it says my car has 4 cat coverters........? is,,,how do i know which one it is.....on the web site it says all 4 are in front of the cat. converter
You have 2 cats...4 O2 sensors. There are 2 before the cats and 2 after the cats. The first 2 help adjust fueling. The last 2 check to see if the cats are still working properly. Since it's a pre-cat O2, you need to get that taken care of fairly soon. Either switch the front O2's from side to side and see if the code follows the sensor (to verify the sensor is truly bad)....or replace it and move on.
I changed one already but my code is still there....so i guess ill take it back to autozone and see if it still flashes the o2 code/// if it does then i guess i need another one...right? and i only saw one while i was under there...anybody got a pic or something showing where they are...
There is one in front of each cat. Find the cats and you'll find your o2 sensors. Did you have the code cleared and it came back or did you just put a new o2 sensor on and hope the SES light would turn off?
I changed the one on the driver side, it was way up by the manifold...is the other one on the pass. side??? and yea i changed the drvr side and now the chk eng light is still on........I figured out that it would have to be reset which i have not done yet..........Then last night i brought it back to auto zone and had it checked again.........showed the same code.........would the code come up still if it has not been reset but the problem had been fixed....the exhaust still smells kinda funky and idles a lil weird..
Your car has 2 cats? Look in front of each of them(closer to the motor). There will be an o2 sensor on both sides. But it will take something like 200 ignition cycles before the code clears itself. Just have the code cleared and see if it comes back.
