What table for open loop idle control ?
in ls1 edit what table has to be changed for cold start and open loop idle ? Trying to smooth out cam I have in a little.
Thanks
Ron H
Thanks
Ron H
Thanks
Ron H
Thanks
Ron H
With the fuel air multiplier table what Kpa readings should I change for idle to reduce fuel and help idling ? Im having problems keeping it idling, I have to keep giving it gas and its running between 9 and 10 to 1 afr according to wideband .
Thanks for the help
Ron H.
Thanks for the help
Ron H.
Thanks for the help
Ron H.
Thanks for the help
Ron H.
The root of your problem could be lying in your VE and MAF table though. Have you scanned your LTFT's lately? If they are very negative it means that the VE and MAF table values are too high, which results in a rich condition, which in turn will drive negative LTFT's in closed loop. Keep in mind that the PCM will not use the LTFT correction during Open Loop either, it will multiply straight off the values in VE and MAF, so if they are to high, the multiplication will be even higher, resulting in very rich conditions.
If your VE and MAF are off, you want to get them dialed in first, and then Open Loop cold startup AFR should lean out for ya.
