handheld capabilities ?
will any of the hand held programmers delete out the codes for the egr and smog . any suggestions on programmer name brands as far as ease of use and total hp gain and total capabilities need programmer for '02 ws6 m6
To answer your question it will show and clear DTC codes but
you can't disable the rear o2's, egr, etc..which is what I believe you are asking? The only way to do it with a handheld, like a Predator, would be in conjunction with custom tuning.
Yep, the Predator can do all of that as long as it has the newest firmware in it.
I am using it on my Formula and it does almost everything you would need it to do plus Diablo is working on a laptop tuning suite to work in junction with the Predator.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by mrr23
the vinci tuner will turn off EGR and AIR, but leave on EVAP stuff.
when you use any of the preset tunes, this stuff is automatically done. you cannot independantly do it.
The Diablo Predator as long as the unit has received the new firmware update or it is a new unit can delete the codes individually.
Originally Posted by Sneakyws6
Incorrect answer...
