Tuning for M6 to A4 swap on 98.
I am in the middle of doing an M6 to A4 swap on my trans am. I have a donar car (both are 98's) and it is a straight swap (all parts including wiring harness etc.). The tune on my M6 car is perfect for my TR224/longtubes/etc. I have done a search and didnt uncover to much. I was wondering what is the best way to change the tune with my HP Tuners. Should I just do a re-write entire to the M6 computer with the Auto cars bin, then upload the calibrations only from the original M6 tune? Or should I just copy and paste all the trans tables from the A4 bin to the M6 bin? I know I will need to do some final adjustments for Idle,etc. Both cars are 98's I have heard that swapping tunes is slightly different for the 98's rather than the 99+'s. Thanks.
i just did my m6 to a4 and i was told there was background files you could not transfer so i just swaped out the pcm too and made the changes from timing, ve, pe, and so fourth from my pcm to the other. worked ok
Well I really dont wanna swap out the PCM. The other car has a bit more miles than mine and I would rather stick with my computer. What other options do I have. It cant be that hard to just reflash for the A4.
Originally Posted by 6-Speed Terror
i think the miles are stored on the dash not the pcm, not sure what other options there are. i would try to change everything to the way it is on the a4 pcm
I would just flash a full image reflash with a A4 file, note: be careful to make sure the full image file your using is not corrupt, or you will kill your pcm.
If it was me doing this swap, I would flash it with a tech 2 as an automatic, and then change your vin back to the correct vin with tuning software.
Ryan
Ryan
So U think I should just take the 98 auto bin and flash it onto my M6 computer, then change the vin back to the correct vin? What should I do about the tune for My cam, longtubes etc, just copy and paste all the tables?
Originally Posted by slikrider20
Manual to automatic?? WHy!!!!
yah know i might not know the first thing about tuning, but that's pretty cool that the tuning capabilities of these cars goes that in debth...maybe i'll start doing some research on this. lol i love learning new things...
and btw, i've heard a lot of people doing A4 to M6 swaps but you guys are some of the firsts i've heard of going the opposite way lol
