what the hell is causing this restriction with my tune???
UPDATE! what the hell is causing this restriction with my tune???
For some reason Im getting a restriction in my upper RPMs and with this restriction, my dyno tuner is not able to lean the motor out at all. My A/f from 4900 starts at 12.9 which is good, but just starts getting richer & richer till we shut down at 6900 which then the A/F is 11.7??
My tuner said he has pretty much "zero" fuel being added up top. but for some reason its stuck at 12.3 at 6500 where I make peak power. Heres my setup.
forged 347 11.25:1 comp.
AFR 205s
G5X4
90/90 setup
new style 85mm MAF with 3 to 5 wire adapter
75mm LID
28.8lb injectors
3" duals with X pipe into borla "S type" mufflers
Kooks 1 3/4 headers
asp U/D pulley
thanks for any help.
AFR 205s
G5X4
90/90 setup
75mm LID
28.8lb injectors
Kooks 1 3/4 headers
asp U/D pulley
Is this with MAF enabled?
Take a look at your IDC. What is it up top?
....also,I know this sounds stupid but has PE Modifier vs RPM table been set?
Originally Posted by NoGo
Wouldn't being out of injectors make him go lean?
He is saying that the car is going rich.
I think their reason is that if the injector goes to max Duty cycle they would go static and stay fully open.
I still think its an adder somewhere or the VE and/or the MAF is out of whack.
Like said before, check the map readings to see if kpa drops off. Also check CAT overtemp.
As dumb as this sounds, make sure your throttle blade is opening all the way. When I put my 90/90 setup on the holes in the cam of the throttle body were in different spots than stock and my blade opened only about half way when I had the pedal to the floor. If you have tcs on your car there's an adjustment in the throttle cable. It's a little square that you can open and adjust the length of the cable.
Originally Posted by 30th t/a
90/90 setup
75mm LID
75mm LID
Post up the log and tune file so we can better advise.
yeh where is he at?? i have run into MANY cars that the cat over temp hasn't been turned off, and people raise questions from that, wondering why their car is rich. between that and the IDC......
Originally Posted by kbracing96
This is funny, up to 17 post with ideas, suggestions and thoughts, but no feed back from the original poster,
he's lurking around. probably lookin' for another dyno.
