Any tips on tuning a HUGE cam????
8 SEC SLOPPY SHOT!!!
Scrap the stock pcm and go with BS3.Ive tryed tuning the stock pcm and was never able to get the car happy.With BS3 i can reach my hand in the window and start the car even when cold.
if you're using HPT ... apply 1 credit for RTT cheap and makes idle tuning VERY easy
for WOT... scan and change, scan and change.... never dealt with anything that big but I'd expect the same concepts to apply
LS1TECH Sponsor
Originally Posted by Frost
Or for 2 credits, get the 1-bar SD AND real time tuning.... hell of a deal for what you can get out of it. I wouldn't screw around with a MAF at all (I'm sure you're not, I'm just throwing that out for others) on a setup like that.
Stick with the factory computer..
Big solid roller around .750 lift. Done with Efilive OS5 (for future nitrous) and a Moates.net road runner. You can accomplish the same thing with Hptuners.
If you are going to stay with the factory PCM go witht he EFI/LIVE RoadRunner setup. Changes are made automaticly just like a aftermarket standalone. No stopping to reflash.
HPT will do all the same and for cheaper. You just have to copy, paste, and flash the PCM before changes are permanant.
with so much overlap, unburned air/fuel is blowing by the exhaust valve borking the O2 sensors, causing it to dump more fuel
idle will have to be done manually, by turning off closed loop in the idle cell ranges, and manually adjusting the AFR until it idles decent, then updating the VE range with those numbers.
be sure to add alot of timing as well. all of this is assuming alot of overlap, but since all he mentions is lift and not any other numbers this may all be unecessary.
BOTH HPTuners and EFI LIVE can do the same thing. we have discovered this.
but for my 0.02 cents; I have efi live. you would be amazed what the stock computer can do with some few mods such as a custom OS or such...
LS1 Tech Administrator
EFI Live Custom OS 5 will allow you to run TPS vs RPM instead of MAP vs RPM for your VE tuning. This makes your part throttle tuning have MUCH more resolution and you can dail that big cam to idle and drive like a much smaller one. If HPT has the same feature, it is very worthwhile to use.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
LS1TECH Sponsor
