Need .ls1 file for 234/238
As a start, you need to take quite a bit of fuel out of the VE table at idle. It should idle fine if you bump up the base spark timing a couple of degrees (23~24* is what mine idles at) and increase the desired idle speed to 850~900rpm once up to temp. You'll also need to dial in the desired idle airflow (base running airflow) so that it's getting enough air to supply a 900rpm idle. Check the stickies at the top of the forum for the RAFIG process. That'll get you going in the right direction...
I'm assuming you're using LS1 Edit, which will make it hard to see. If you can read an EFI Live file....sure. Mine saves as a *.tun file. I can't save it as a *.bin or a *.ls1 file though. Just PM me your email addy and I'll send it your way.
Custm2500's #1 Fan
I said idle CORRECTLY.... as in, slow driving speed, red lights, a/c on, power steering pump drag... etc etc... I dont think drivability is taken into enough consideration when choosing cams. I have a relatively small cam (for an LS1) but in my 5.3 it took a lot more work to get the same idle quality. Those are just my opinions and experiences though... it just doesnt take a ton of duration in these motors to make nice gains.
Originally Posted by 1984camaroz28
its hard tp learn by ur self its basicly trial and error
The stickies here are a good place to start. They can give you a general idea of what we believe to be true about the way the tables relate to one another in the PCM. That's the key to understanding how to tune...understanding what the tables do and how they interact.
If you wanted immediate results, you should have paid someone to tune it instead of trying to do it yourself.
