need help finding clutch switch wire off ecu
Old 08-09-2007, 05:50 PM
SVC707's Avatar
Default need help finding clutch switch wire off ecu
ive had enough of this search buttun not working
im trying to finish installing a synergy 2-step and cant find the clutch switch wire off the ecu, the instructions say blue connector #35, but that location is empty? so im guessing the directions arent for an 02.
Old 08-09-2007, 06:16 PM
shotty128's Avatar
you are correct pin 35 for an 02 T/A is not used
shotty128's Avatar
you are correct pin 35 for an 02 T/A is not used. That is because for an 02 ta its pin 34
pin connector
ic1 26 c2
ic2 67 c2
ic3 69 c2
ic4 29 c2
ic5 68 c2
ic6 28 c2
ic7 27 c2
ic8 66 c2
engine speed 10 c2
clutch switch 34 c1
pcm power 20/19 c1 pin 19 is ignition voltage pin 20 is battery you probably want ignition
Old 08-09-2007, 06:37 PM
shotty128's Avatar
let me know if that works for you
Old 08-09-2007, 06:57 PM
SVC707's Avatar
34 in c2? blue
Old 08-09-2007, 08:26 PM
shotty128's Avatar
that pics helps more pin 32 is the cpp switch. I didn't see you were giving me half the ecm pic
32 grey cpp switch
34 ORN/BLK neutral safety switch
cpp stands for clutch pedal position
Old 08-09-2007, 08:31 PM
shotty128's Avatar
I just found this link.
http://www.ls2.com/boggs/torques/2002pcm.htm
SVC707's Avatar
thanks, i was about to tear it apart to test the clutch pedal but no fluk meter. figured it has to be somewhere to also cancel out the cruise control when depressed.
you must be a gm tech to find out so quick... if you ever doing side work for nissans i can get you all the info you need on them
Old 08-09-2007, 08:35 PM
SVC707's Avatar
cool. i only found one for a 98 pcm, couldnt find the 2002
Old 08-09-2007, 08:37 PM
shotty128's Avatar
Naw I am not a tech
Old 08-10-2007, 12:52 PM
GlennNo50's Avatar
Originally Posted by shotty128
Not a gm tech. Just think much much higher up.
GOD????
