Found a Tuner that used Tuner Cat software
found a local tuner that tunes with Tuner Cat software. He is actually in Columbia, MO. I asked him some questions about how he tunes and here is his answers.
What kind of software do you use?
Tuner Cat
Also, do you change the A/F ratio for maximum
fuel mileage.
In cruise mode
And how what kind of mileage gains could
I get with the 4.8 V-8 and the 5.3 V-8.
I have seen 2 to 5 mpg depending on how you drive.
I would like to get a tune from this guy, but I haven't really heard anything about him. And also what is tuning in cruise mode all about? Let me know what you guys think.
Tuner Cat
fuel mileage.
In cruise mode
LS1TECH Sponsor
Tuner Cat
fuel mileage.
In cruise mode
Tuner Cat
fuel mileage.
In cruise mode
I don't want my truck to run lean, just wondering how he gains his gas mileage of 2-3 mpg that he claims. Has anyone else used tunercat software on 01 or 06 pickups. How does it work anyway?
The software works fine. It is not as fancy or as EASY as efi or hp but it will do just fine.
Be more concerned about the person using the software more than the what software he uses. I am not saying anything bad or good about the tuner you are referring to, just in general.
lean cruise is not used in the us because of emmissions.
some holdens use a lean cruise
tuner cat updated their VDF files a couple months ago.
some people claim to have it figured out. i plan to be one of them soon. its no joke it does work and it will not burn your car down when done right.
i have been working on tring to find some stock holden tunes that i can read.
lean cruise enabled at between 1200 &2800 rpms at light to no load could bring some good gains to highway miles.
Well, I emailed this guy and asked him if he does the A/F ratio for max. fuel mileage. He replied "in cruise mode". So what does Cruise mode mean? Also, he wants to charge $300 for a tune, with free updates. Is that reasonable or can I buy the program myself for that amount of money? I now have a wester's tune in my truck, but it is a mail order tune, and I would think getting a tune done in person would be a lot better, don't you? Also, with tunercat software, can you tune it while you drive, or is that only available with the other software that is out there?
It is good software. It's also easier to navigate once you become familar with the interface. IT does require the user to memorize table names though and how to decode them.
Unlike HP and EFI tunercat segragates the constants single byte values and the table 2d and 3d arrays. It'll look like fewer tables in reality but its not becuase its not a tab window based layout.HP is missing a ton of idle controls that TC has. I know becuase I have both.
On of the best GUI differences between the 3 differing software companies is the way TC lays out its Diagnostic code interface. Its far easier to navigate. TC breaks up the codes by type so you have fuel/emissions/ignition etc etc etc in the approiate sub categorys.
Originally Posted by SSpdDmon
I got a chance to see a copy of it at a shop here in MI. Definitely laid out a little different than what I'm used to (EFILive). It also seemed to have access to less tables (maybe because it was an older version???). However, it did have one cool feature that allowed you to adjust the 3-D maps with the mouse using a click and drag. We can do that on our 2-D maps....but, not the 3-D's.
