Which LM-1 is ideal for EFILive/Roadrunner?
Old 10-22-2007, 05:31 AM
The Dragon's Avatar
Question Which LM-1 is ideal for EFILive/Roadrunner?
http://thunderracing.com/catalog/?ac...d=666&pcid=155
Anyone have useful experience with any of these LM-1's?
Old 10-22-2007, 06:26 AM
Eurospec2's Avatar
If your using EFI Live and the roadrunner you can save some money and not Buy the LM-1, you can buy the LC-1.
The LC-1 is the same sensor/controller but it does not have all the datalogging functions, but since you have EFI Live you dont need those functions anyways
Old 10-22-2007, 09:55 AM
Moderator
jimmyblue's Avatar
Contrariwise, if you plan to work on multiple vehicles, the "meter"
form of the LM-1 is a lot more toolbox-tolerant and portable; to
work on old non-EFI motors you might want the RPM converter
and if you were going to go really nuts like instrumenting up MAP
or whatever to pick your Holley power valve P/N for example, the
AuxBox would be handy.
For just what's stated and not wanting more A-pillar blinky-blinky
I'd say the basic LM-1. "Analog output cable" is a stereo 1/8"
patch cord, don't pay extra for that. Kit should come with a
wideband bung and plug, don't use the plug (soft stainless Allen
which will end up stuck and round out on you) but get a Toyota
18mm oil pan drain plug from the Zone.
Old 10-22-2007, 12:38 PM
The Dragon's Avatar
After my experience with the LC-1 I'll never use, nor will I recommend, that wideband sensor ever again.
Thank you Jimmy!!!
This is EXACTLY the answer for which I was searching
Old 10-22-2007, 04:24 PM
Black02SS's Avatar
I have used my LM-1 that I bought from Lingenfelter over 3 years ago non-stop. Only thing I did was replace the sensor. Since then I have sold a ton and never had one customer return or experience any problems with them.
Old 10-22-2007, 09:02 PM
The Dragon's Avatar
Thumbs up
Jimmy, will the resistor in the SLP 85mm MAF degrade or malfunction in time?
I ask because it was fairly easy to re-tune with the SLP unit as/is; therefore I wouldn't want to tune all over again without the resistor
Thanks for the help BTW
How much and do you have the basic LM-1 in stock?
Old 02-27-2008, 09:16 AM
Jpr5690's Avatar
Yea The Lc-1 Kinda Sucks I May , May But A Lm-1 Being It Is Less Tempermential But The Lc-1 Is Just Too Senstive To Be Called A Good Product
